ramster
The 999cc Fire 45S Uno works perfectly until I turn on the lights. As I turn on the side light the engine revs slow down. When the headlights are turned on the engine revs slow down more to the point that eventually the engine will stall. The engine always starts up again and will run OK when the lights are switched off. Other loading such as the heated rear window or engine coolant fan do not interupt the engine revs. I have cleaned the earths at the battery neg terminal and also on the inside inner wing near the headlight on the opposite side to the battery. The alternator has been tested and is OK. Any thoughts please?
