excursion_uk
Im not sure if this problem has been mentioned before, i think it has but to be safe ill post a new topic with my exact problem.
rite
i have a 1994 fait uno 999 fire.
i have a little problem with the engine acceleration.
the problem is my accelerator, when the car is out of gear (and in gear) i hold the accelerator down to rev the engine the accelerator revs fine. but when i hold the pedal steady bout 1/2way down or whatever and hold it the engine varies speed, like im moving the pedal but im not. this effects the driving of the car so when im accelerating the car pulls back like im easing off the pedal, you can see how this would annoy someone.
the engines varing speed appears to go up and down in a pattern, its not a random noise it happens the same distance apart, about a second between each rev dip.
if i hold the throttle cable tight from inside the engine the engine still fluctuates.
this problem has always been there so anything ive done to the car below hasnt fixed it
ive replaced the head gasket
throttle positioning sensor
general service. oil/water change filters changed. the usual
really really, if anyone has an idea fire them my way.
im not looking to spend a lot more money on it. so please if u suggest replacing a part give me the price aswell, if ya can.
rite
