I had a clonk, maybe that is not how to describe it, as you turned the steering wheel. It turned out to be the flat 1 mm thick bearing plate that was completely dry and full of dirt.
Easy fix, I already had a spare suspension unit.
Just thought I would post it up for others.
And, I a sure I read somewhere on here that turbo spring were a different thickness and were colour coded blue or green and standard springs were coded white and yellow. Can anyone confirm this, I can not find the relevant thread. I was sold what were supposed to be turbo springs and front shocks but I can not see much difference if any at all. The springs certainly seem to be the same diameter.
