Finally it is time to get my 1600 Tipo engine into my 84 70s.
I also have a partially burnt out 70SL, only some plastics in the engine bay are melted. It has the later bottom change gearbox.
I will use all the relevant 70SL parts I need to get a gearbox and engine together. Starter Motor, flywheel, head and manifolds etc.
It will only be used as a road car.
Questions:
Should I use the Uno cam or the Tipo cam.
Should I get the 1300 head skimmed very much or just enough to make sure it is straight. (I also have an 1100 I could use the head from.)
Will I have any issues mounting the later gearbox into the 84 Uno.
What about the driveshafts, they look different.
Will I have to replace the hubs and rotors too.
I hope JJ is still looking in here, but I don't need a beast like his!!
Thanks all,
/R
Questions:
Thanks all,
/R
