Your trusty help is needed for my poorly 999cc FIRE mk2...
Problem 1:
I have an idle problem when cold. Basically one minute its fine, then it sounds like its firing funny and the exhaust blows out with alot more force. the revs drop and bounce between 500 and 1k, and you can smell more petrol.
Different amounts of choke dont seem to be solving the problem. I had originally put it down to the cold but it was a nice warm day today and it still did it. As soon as its warmed up or the engines got into its stride, its fine. So could it be possibly something to do with my carb - like deposits in the idle jets or dirty throttle body?
If so, do any of you know where i can get hold of a reconditioning kit (gasket, vacuum unit for the carb, and whatever else i needed to do a proper service)?
Problem 2:
Could my Cam be knackered? My engine had run for some considerable time with no oil pressure and subsequently has worn/burnt my cam. The valves didnt look too healthy either. So when im driving around when its colder, the car badly lurches forward and looses ALL power momentarily - its as if you go and it stalls (without engine stopping). As soon as it warms up (50 deg.) its fine. Its also fine cold with at least 2k of revs on the choke. Any less then it does it.
Problem 3:
The breather tube on the engine that goes into the airbox... Is that supposed to be sucking in air via that way or blowing air out?
Basically it seems like mine is using it as a secondary exhaust as it constantly blows exhaust gases through it into the airbox, and in turn, straight down to the carb again.
Problem 4: (Last one)
I have a slightly wierd idle now i've put back on a new vacuum advance unit. Sometimes in town driving the idle is fine, about 900 revs. But when on the motorway and driving around a little faster, the idle usually sits at 1200 but fluctuates a 100 or so. Whats causing this??
So as you can tell, im either paranoid about my poor engine or its truely poorly.
Problem 1:
Problem 2:
Problem 3:
