Old 06-02-2005   #1
Malta
Clutch slipping
Hi there,
how can you tell that your clutch is slipping?? Im worried because as soon as I start off first thing in the morning its like the car doesnt move or it hesitates. Is that a sign of the clutch about to go bye bye!
My car only has around 27,000 miles so I dont expect it to go that quickly! I've only had it for the last 2000 miles. The woman who owned it b4 me had the habit of balancing on the clutch!! Thanks
Mods:
Clear indicators
GT Auto Alarm
White dials
Autometer Rev-counter
Boot light
Alloy wheels 185/55 R14
Sprayed Disc brakes
x2 8" rear speakers
x2 4" front speakers
Kenwood CD player
Drinu is offline Reply With Quote Quote
Old 06-02-2005   #2
Trader Rating: 1
Luke has donated!
George Wants Beer Champion, Home Run Champion
Re: Clutch slipping
Quote Originally Posted by Drinu
Hi there,
When you're on the motorway or fast roads, (basically in a high gear) take your foot off the accelerator and then put your foot to the floor. If the revs go up then level off then its probably slipping.
Luke is offline Reply With Quote Quote
Old 06-02-2005   #3
Trader Rating: 1
whatoncewas has donated!
Re: Clutch slipping
Or... once the car has warmed up, just rag it one in every gear and see what happens. Same thing, if it slips, it's going...
whatoncewas is offline Reply With Quote Quote
Old 08-02-2005   #4
Malta
Re: Clutch slipping
Thanks guys tried it and it seems that it did not slip!! However last time I was stuck in some really heavy traffic with lots of stop and go...and at the end..the clutch sort of lost that 'bite' when you let it go at once!! That is what is worrying me!! Also...when I race the car after a while you can smell the clutch from the outside! I know that is not a good sign!!
Mods:
Clear indicators
GT Auto Alarm
White dials
Boot light
Sprayed Disc brakes
x2 8" rear speakers
Kenwood CD player
Old 10-02-2005   #5
Trader Rating: 1
Re: Clutch slipping
Maybe the cable is just getting too hot at those times, for example, and causing a 'drop'?
Or hydraulic fluid?
Old 12-02-2005   #6
Malta
Re: Clutch slipping
Could be the cable! Hydraulic fluid is just fine!!
Will have it checked for next service!!
Mods:
Clear indicators
GT Auto Alarm
White dials
Boot light
Sprayed Disc brakes
x2 8" rear speakers
Kenwood CD player
Old 13-02-2005   #7
Trader Rating: 1
alexGS has donated!
New Zealand
Re: Clutch slipping
Yeah, you either have a cable clutch, or a hydraulic clutch, not both
I think the easiest way to check the clutch adjustment is to look at the height of the clutch pedal compared with the brake pedal. FIAT specify the clutch pedal travel, but I reckon the clutch pedal should be level with, or just below, the brake pedal, for best results.
If the height of the clutch pedal seems to change, then you might have a cable or hydraulic fault. But I think the hesitation that you mention is probably some other cause with the fuel injection... If the clutch was slipping, you'd be feeling it each time you re-engage after changing gears... there would be a sort of smooth 'delay' in the drive...
-Alex
'15 Giulietta 1.4MA, 14 Abarth 500C Esseesse, '08 500 Lounge 1.4 Dualogic, '08 G Spyder, '71 850 Coupe in bits...
alexGS is offline Reply With Quote Quote
(T) Strange Clutch problem Julio_Scorchio Cinquecento / Seicento 21 16-11-2008 02:02
(T) Clutch - cable or clutch itself? SnowBord Cinquecento / Seicento 12 13-02-2005 17:18
(T) no drive from clutch chopperdawg Punto (Mk2/2b) 10 22-12-2004 22:52
(T) Punto Mk3 clutch questions radicool Punto (Mk2/2b) 2 19-11-2004 21:57
(G) Anybody got a spare clutch? stiloactive Stilo 2 25-06-2004 04:05
