im Axle Specialists
Old 27-05-2010   #1
Working Seicento at last!
firstcar-Y10's Avatar
Trader Rating: 1
firstcar-Y10 has donated!
1108 carb jetting
query for any clued up techy types. Got an 1108 carb FIRE engine out of a mk1 but at the minute I have 3 carbs and a selection of jets lying about, mostly I think off 999 engines. So, does anyone know the correct jet sizes for the 1108 and is there any difference from the 999???
THE MIGHTY GRUMBLEWEED
firstcar-Y10 is offline Reply With Quote Quote
Old 27-05-2010   #2
Powered by Bacon.
Ucof's Avatar
Trader Rating: 1
Ucof has donated!
Re: 1108 carb jetting
All I can find in the Haynes is (from chapter 13.73 in the Mk2 Red manual):
"The Bosch Mono-Jetronic fuel injection system fitted to the 1372cc ie engine and later 999/1108 'FIRE' models is an electronically-controlled single point injection (SPI) system."
To me, that sounds like the 1108 and the 999 injection systems are exactly the same, so jets *should* fit between them.
However, this is entirely an educated guess based on my interpretation of what it says!
Thanks firstcar-Y10 thanked for this post
Ucof is offline Reply With Quote Quote
Old 27-05-2010   #3
Trader Rating: 1
thanks for the response. It's a carb'd engine though not injected, not many carb 1108s about. Just wondered if anyone had pulled one of the carbs apart. been having rough idling problems and boring out one of the spare idle jets slightly has smoothed it right out, just wondered if the rest were right or if I'm still looking for an air leak further down.
Old 27-05-2010   #4
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Louie Bee has donated!
Rollin X Pinball Champion, Bubble Bobble Champion
Mozambique
[QUOTE=Ucof;2504443]All I can find in the Haynes is (from chapter 13.73 in the Mk2 Red manual):
QUOTE]
Hell no, the The Bosch Mono-Jetronic fuel injection system was fitted to loads of cars as the use of carbs was phased out in the UK, so has many options.
Don't think the MK1 Uno ever came with the 1108 but perhaps the errly MK2 with carb here.
Thanks Ucof thanked for this post
Louie Bee is offline Reply With Quote Quote
Old 27-05-2010   #5
Powered by Bacon.
Ucof's Avatar
Trader Rating: 1
Ucof has donated!
Good points.
All I can say was that it was early morning posting...
Old 27-05-2010   #6
Chas Uno has donated!
Air Dodge Champion, Asteroids2000 Champion, Frogger Champion
Exclamation Re: 1108 carb jetting
I'm away from home at the moment so I can't check my Haynes manual for details, but I do know the following:
The carburettor fitted to 999cc and 1108cc FIRE models are the same in terms of physical venturi size but there are subtle differences in jetting. The Haynes manuls gives details of which jets are different. Both sized engines will run with either carburettor, though for optimum efficiency the correctly jetted carburettor should be used. If you have access to a mk2 Uno Haynes manual you can find the details of the 999 and 1108 jetting in the supplement section, near the beginning and in the fuel system specifications part.
Louie is right in mentioning that the mk1 Uno never had the 1108 FIRE fitted as standard. 1.1 Uno 60 mk1 models used the older 1116cc Lampredi whereas 1.1 Uno 60 mk2 models used the 1108 FIRE engine.
Hope this helps!
Quote Originally Posted by Trinity View Post
we got a lot 126 here in Egypt .. a funny car and fun to drive though sometimes i feel like I am sitting on a chair in the middle of the street
http://onastick.net/drew/sinistar/
Chas Uno is offline Reply With Quote Quote
(G) Carb dale2507 Cinquecento / Seicento 9 15-09-2007 12:04
(T) carb INsantiy Tempra 2 01-02-2007 14:11
(G) Weber DCNF Jetting? 128plus X1/9 2 12-01-2005 22:49
(G) Carb flat spot Uno 60S (Solex carb) Brymak Uno 3 29-11-2004 02:06
(G) panda weber 32 tlf jetting panda racer Panda (Classic) 10 29-06-2004 02:02
