- Oct 1, 2004
- 63
- 21
Uno 1.1. i.e. erratic idle
Hello!
Iv'e got a uno with approx 100.000 miles and I have a idle problem which grow up during the last 2 years (yes, but it started very very softly).
It is evident only if external temperature is less than 10 celsius degrees and it starts as soon as engine starts to warm up (when it is cold it runs good).
If I accelerate and then I live engine at idle (or if I stop at traffic light or similar) idle cuts and then rises up, then cuts... This problem starts after a few minutes from turn up the engine (if it's cold, idle is increased by ECU) and its more and more evident as soon as external temperature is low. Sometimes it cuts out. I also noticed that if I stop the engine (with the key) and then I try to start it, it takes more times to start up respect to a total cold starting.
Lambda voltage is quite static at a low level (0.1 - 0.2 V) when at idle, can this mean a lean mixture? Despite, lambda voltage is correctly up and down during running on a street.
Vacuum advance is good (no leaks) and also sparks, plugs and similar.
However engine runs fine in all other conditions, low fuel and oil consumption etc...
What can this mean?
Let me know if you have an idea!
Thanks a lot,
Andrea.
Hello!
What can this mean?
Thanks a lot,
Andrea.
