Thread Tools
Old 15-01-2005   #1
No oil to cam
I have a uno I.E 999 cc. Ive sorted the noisy distributor but now I've got another problem.
No oil feed to the top of the engine. Ive tried flushing oil followed by fresh oil. NO JOY.
The cam feed pipe is clear and clean. The feed oilway appears clean. You get the oil warning light with ignition switch on, then as soon as you start the engine the light extinguishes as normal indicating there is oil pressure of some sort.
Take the rocker cover off whilst the engine is running and there is NO OIL FEED whatsoever from the cam feed pipe, so the cam is running dry. The car has done 65000 miles verified. Any ideas ??
How much is a new oil pump ?
necessaryevil is offline Reply With Quote Quote
Old 16-01-2005   #2
Trader Rating: 1
Luke has donated!
George Wants Beer Champion, Home Run Champion
Re: No oil to cam
I had the same problem with mine, standard 999cc non IE. I blew the whole system through with compressed air and parafin and gave it a good clean. Took all the parts off - took the gears off teh oil pump and gave them a good clean etc forced air through all the channels.
Put it back together and all was well. Couldnt say exactly what the problem was and what exactly fixed it, but stripping down the engine and giving it a complete clean/overhaul made all the difference
Not sure how much a new pump would be. It may be worth taking the old one off first and seeing if the gears are infact actually worn or not - otherwise it'll be a waste of money, as the underlying problem my be elsewhere such as the oil channes are blockedl
Luke is offline Reply With Quote Quote
Old 16-01-2005   #3
Re: No oil to cam
Thanks for that, I will certainly give it a try first, however I do believe that it is a problem with the oil pump. Possibly the pressure release valve is stuck, this would result in low oil pressure. I could still do with finding out the price of a new pump tho ??
Old 16-01-2005   #4
Trader Rating: 1
Luke has donated!
Re: No oil to cam
Quote Originally Posted by necessaryevil
have a look on shop4parts.co.uk
Thread Tools
(T) Gearbox oil leak... Gman Cinquecento / Seicento 17 08-02-2006 09:55
(G) Uno 1.0ie alternator replacement trublue Uno 16 28-11-2004 16:09
Super Mirafiori twin cam 1984 / oil supply / extreme angles themannsindorset Lets Talk FIAT 2 19-08-2004 18:25
(T) My X1/9 twin cam conversion fiatfactory X1/9 2 19-08-2004 14:59
(G) Electronic Oil Level Indicator Lou Ulysse 2 12-05-2004 20:38
