Hi Guys,
New to the forum and need some help please. Just recently bought an 99 Uno 1.1 Mia. I am busy changing the CV's joints (both inner and outer), and came across a stumbling block. When changing the inner cv, i noticed that its not your "normal CV" (i always drove a VW golf, and the inner looks very similar to the outer, and bolts onto the gearbox), but instead on the Uno it has a "tripod" with bearings which fits directly into the gearbox, and is not fixed onto the gearbox with any bolts.Then the CV boot goes over this. Now when i removed the complete shaft, oil started running out from the gearbox, from where i removed the inner cv. Is this gearbox/transmission oil?
Once i fit the complete shaft again, should i then just top up the gearbox with gearbox/transmission oil? Also, is there anything in place that prevents this oil from running out of the CV boot once fitted. Or does the "tripod" create a seal in the gearbox which prevents this? Or should i just ensure that the boot has a tight seal?
Many thanks for any help. The car is currently standing without any CV's, and i need this fixed asap.
Thanks.
Thanks.
