Old 01-11-2009   #1
No fuel from injectors??????
So finally got the turbo back in my MK1 and now it wont start. Has spark and fuel pressure at the fuel rail but the plugs are dry so dont think the injectors are working. I had also had the dash out and battery off but now its all back together it just wont stat. Have checked everything i can think of. Thought it could have something to do with an imobliser on the alarm but couldnt think where you could put a relay to do that. Any ideas would be well recieved as i dont have that much experience with injected cars. Thanks Bjorn
UNOMK1NZ is offline Reply With Quote Quote
Old 01-11-2009   #2
Powered by Bacon.
Ucof's Avatar
Trader Rating: 1
Ucof has donated!
Re: No fuel from injectors??????
Give the injectors a clean and a soak in injector cleaner and see if that helps at all.
When you say that the engine will not start, what do you mean? Is it dead, or will it just not turn over?
Ucof is offline Reply With Quote Quote
Old 01-11-2009   #3
Yea might give that a go but i thought since all spark plugs were dry (meaning all injectors arent giving fuel through) that its something electrical. It turns over fine and has a good spark but just wont ignite and im putting that down to no fuel getting through. Does any one know how you can test the wires that go to the injectors to see if they are getting the siginal.
Old 01-11-2009   #4
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Remove the wiring plugs from the injectors and connect a NOID light to them (one at a time unless you've got 4 NOID lights). Turn the engine over and the NOID light should flash if they're getting pulses from the ECU.
Dave.
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 5 of 215/45-17 Alloy Wheels
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 01-11-2009   #5
Most likely the fuel pump relay. Check crank sensor too.
Racky-80 is offline Reply With Quote Quote
Old 02-11-2009   #6
Well now i have checked the siginal going to the injectors and there is no siginal. The fuel pump must be working because there is pressure at the fuel rail. Does the pulse (siginal) for the injectors come straight from the ecu? im running out of ideas
Old 02-11-2009   #7
FIXED !!!!!
Searched back on earlier posts about the injection system and saw it uses the coil so looked all around it and found a very inconspicous wire that had come off .
Cheers for the help guys
Havent had my baby on the road for over 6weeks so looking forward to a blat 2morrow.
Old 02-11-2009   #8
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Yes.... there should be a permanent 12v +ve live feed to the injectors whilst the ignition is switched on and the -ve trigger pulse comes direct from the ECU.
Dave.
Old 02-11-2009   #9
Powered by Bacon.
Ucof's Avatar
Trader Rating: 1
Ucof has donated!
Woohoo!
Glad to hear everything is working again! :d
Old 17-11-2009   #10
hi , does anyone know if this would apply on a 200 punto hgt as i have EXACTLY the same problem! have alos tested with noid lights and have no output, however i do have 12v at the injectors with ignition on, any help greatly appreciated!
smithmagic is offline Reply With Quote Quote
Old 18-11-2009   #11
Trader Rating: 1
alexGS has donated!
New Zealand
Totally different engine management system (and different engine!) in a Punto HGT - best you post in the Punto forum There won't be an ignition coil connection (each plug has its own coil) but I think the injectors will have a 12v supply that you found. On the Uno, the injectors are all switched together, so one fault stops all four. On the Punto HGT, each injector is switched separately (sequential injection) so there are other possible faults - cam angle sensor (though I think it reverts to non-sequential if faulty).
I think the best place to start is to check all system fuses, then check if you have sparks at the spark plugs (the crankshaft sensor is shared between ignition and fuel injection on the Punto). Pop over to the Punto forum and see what they suggest?
-Alex
'15 Giulietta 1.4MA, 14 Abarth 500C Esseesse, '08 500 Lounge 1.4 Dualogic, '08 G Spyder, '71 850 Coupe in bits...
alexGS is offline Reply With Quote Quote
Old 18-11-2009   #12
hi there, thanks for reply! have been in the punto bit but not havin too much luck in solving my problem, ive got a good spark and all the fuses seem to be ok,could i have a prob with the fuel relay?even though ive got fuel up to the rail, sorry about all the q's but u seem to know what your on about
Old 19-11-2009   #13
Australia
That's not common. The ecu is not switching the injectors for some reason. I always double check my tests when I find this because its very rare. A scope is better than a noid light if you have one.
Its so rare I would think you have a fuel pressure problem rather than an injector firing issue. Have you tested fuel pressure? pump and relay etc
Check all the angle sensors and good power and earth at the ecu. Also check injection pulses at the ecu, start there
SteveNZ is offline Reply With Quote Quote
Old 19-11-2009   #14
rawill has donated!
New Zealand
I am continually amazed at the information that is able to be found on here, and the very helpful and knowledgeable people who give out that information in a constructive way.
Thanks to all contributors, I enjoyed reading this thread even though as yet all my Unos are old carb models.
Although I did wonder what it would be like to put a 1990 1500 injected Mitsi motor in one. Why, because I have a repossesed 1500 Mitsi motor here in a car that will not go back on the road.
UNO 84-70s,
03 V6 Renault Laguna, SAABs 97 9000CD st I, 93 9000griffin st II, 93 9000CSI, C900 LPT vert,
Others:73 Rover P6B (project) and 1 Suzuki GT380
rawill is offline Reply With Quote Quote
Old 19-11-2009   #15
Rawill, your going to have to get a project thread up now :P you deffo gotta do it haha, sorry to go off topic
Dan
EssexUno is offline Reply With Quote Quote
(G) Fuel Injectors... Ray11 Punto (Mk2/2b) 2 10-02-2009 18:10
(G) Fuel Injectors rikmargetts Bravo / Brava 2 29-05-2007 09:26
(G) Can I clean fuel injectors myself Black_1.2_mk1_Sporting Punto (Mk2/2b) 5 07-02-2007 18:21
(T) Fuel injectors o_donnell_kevin Marea 1 23-12-2004 15:28
(T) fuel injectors david ftt Punto (Mk2/2b) 0 18-10-2003 00:05
