im Axle Specialists
Thread Tools
Old 24-06-2009   #1
rawill has donated!
New Zealand
Air cleaner Summer/winter setting
I have hunted, and read the Haynes, but haven't found how to get the Summer/winter flap inside the aircleaner spout to stay in the summer position.
Mk1 Uno 70s and Mk1 Uno 60s
UNO 84-70s,
03 V6 Renault Laguna, SAABs 97 9000CD st I, 93 9000griffin st II, 93 9000CSI, C900 LPT vert,
Others:73 Rover P6B (project) and 1 Suzuki GT380
rawill is offline Reply With Quote Quote
Old 24-06-2009   #2
Powered by Bacon.
Ucof's Avatar
Trader Rating: 1
Ucof has donated!
Re: Air cleaner Summer/winter setting
Duct tape!
(no idea, sorry )
Ucof is offline Reply With Quote Quote
Old 24-06-2009   #3
rawill has donated!
New Zealand
LOL. Thanks. I think, throw it away.
UNO 84-70s,
Old 25-06-2009   #4
Barney vd Merwe has donated!
South Africa
[QUOTE=rawill;2133806]I have hunted, and read the Haynes, but haven't found how to get the Summer/winter flap inside the aircleaner spout to stay in the summer position.
Which Uno model is this: 999cc/1108cc/1301cc Turbo/1372cc carburettor OR 1372cc Spi , 1372cc Turbo ?
Barney vd Merwe is offline Reply With Quote Quote
Old 25-06-2009   #5
rawill has donated!
New Zealand
How silly of me. Either 1108 or 1301, lampredi engine. see photo. The S/W flap is inside the inlet section where the warm air duct joins the main inlet duct.
Name:	air cleaner.jpg
UNO 84-70s,
Old 25-06-2009   #6
Trader Rating: 1
alexGS has donated!
New Zealand
It's thermostatic - automatic - or was, once!
A small brass capsule is intended to expand and close off the hot air intake by the crude plastic linkage. I don't think these ever worked very well. Ten years ago I could only find one that worked, out of a collection of five.
What I would suggest is to remove the dysfunctional parts and fit a screw to the flap pivot, so you can set the flap position to 'winter' for the present conditions. You might also need to check/replace that relatively-expensive aluminium duct pipe from the exhaust tin shield. It is worthwhile in the winter - helps prevent carburettor icing and generally enhances the carburettor operation during the warm-up phase.
-Alex
'15 Giulietta 1.4MA, 14 Abarth 500C Esseesse, '08 500 Lounge 1.4 Dualogic, '08 G Spyder, '71 850 Coupe in bits...
alexGS is offline Reply With Quote Quote
Old 25-06-2009   #7
rawill has donated!
New Zealand
Aha, funny you should say that. I pulled one apart, and was thinking it must be something like this. Then I read your post. Is this an example of where Haynes is not up do date? I read about a manual adjuster, mechanism but that must be for another type, or earlier! But how much earlier can you get from 84.
UNO 84-70s,
Old 26-06-2009   #8
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Louie Bee has donated!
Rollin X Pinball Champion, Bubble Bobble Champion
Mozambique
The Uno 45 (903 cc version) has a similar looking round air filter housing.
on this version, you remove the cover, turn it 180 degrees and put it back, to switch between summer and winter
Both my 903cc Unos had it, one was 1986, the other 1988
Louie Bee is offline Reply With Quote Quote
Old 23-07-2009   #9
biggaitch the abbotman
biggaitch has donated!
don't break the flap or leave it open in the winter...my first fire engine would freeze the carb in winter and slowly come to a halt,,,after 20 mins .tiny engine heat would melt ice in carb and away we would go!!!took me a long while to suss that!
biggaitch is offline Reply With Quote Quote
Thread Tools
(G) Injector cleaner and throttle body cleaner doidge0 Punto (Mk2/2b) 1 23-10-2015 13:47
Winter blues? Feeling pasty? Want that summer glow? Hellcat Leisure Lounge 5 06-02-2009 15:48
(T) air cleaner sealing ring usernut Punto (Mk2/2b) 2 12-01-2008 16:08
(G) Air Cleaner/Filter Side Clips 1986_1000S Panda (Classic) 4 24-11-2007 19:02
(G) Its summer and i've only got hot air wilharper2000 Panda (Classic) 3 10-09-2006 07:48
