Hi all I just bought a 92 uno 1.1 for my girlfriend and the front right indicator bulb seems to have gone how do I get to it to change it I can get to the headlight bulb but cant figure how to get to the indicator do I have to take out the whole headlight assembly?
I'm not all that familiar with the Mk2 Uno but I believe it's a similar design to the Tipo headlights.
Look for a plastic tab clip that prevents the indicator from sliding forwards. I think you can pry this tab outwards if you use a screwdriver through the gap between the headlight and the front wing. The indicator then slides forwards to release.
Perhaps it is just as easy to take the headlight off, which gives you the opportunity to give everything a clean. Be aware that the headlight has a plastic reflector and you must only use 'gentle' soap to rinse it - not clothes-washing detergent.
u take the headlamp unit off the unclip the indicator takes 2 mins u mite b able to get away with not takin the grill off but then the grill is only 2 screws anyway and the headlight is 3 10mm nuts all u hav to do is undo the nuts an screws an then unplug the bulbs an the indictor then u cna just pull th ewhole unit off an unclip the indicator off the headlight swap the bulb over an put it back together
