Hi!
I own a Fiat Uno 45 IE (999cc) 1990 model. Lately i've got some problems with my car so i've started to look at the temperature meter a bit more often.
I've noticed that the temperature meter goes above the 90 degree normal, by one or two "ticks". Im worried about overheating of the engine. The Cooling fan works normally, and starts to operate when the meter goes above 90 degrees (though it stops when the meter is still above 90 degrees)
I've also noticed that there's a leak of cooling fluid coming from somewhere beneath the engine. But the leak STOPS if the fluid has leaked 1 CM ABOVE the Minimum mark of the coolant tank. After that the cooling fluids dont leak anymore.
Where could the problem be? Could the waterpump be broken or leaking?
i've checked all the hoses coming from the coolant tank and going in to the engine, they all seem to be DRY.
Could the temperature meter simply be off by a few degrees, since cooling fan starts to operate and stops?
Or could the thermostat be broken, (worked nice in winter -20 degrees etc, warmed nicely to 90 degrees)?
Any help is appreciated, i would love to pinpoint the problem so that i dont have to guess where the problem is. Thanks in advance!
