Likewise. I'm sure Pandas and Unos aren't too diferent mechanically.
Wheels look nice Matt, but!! they're five stud.. and Fiat are 4 stud hubs... unless you have differnet ones?
hi there,thankyou!
also, the fuel pump makes lots of noise and some ticking,and dosent prime properly i.e., when the ignition is on, the fuel pump is running and dosent turn off by itself - to get it to run i have to syphon fuel to the carb through the pump before i start it - is the pump buggered or is it just the wrong type or something ?
any ideas appreciated
cheers louie,
dunno if its got a choke actually should ahve checked lol :bang: but i dont think it does. a choke not on wouldnt cause massive misfire would it?
yeah distributor is on the list of things to check when i next see it...
Sorry RSF I missed your reply till now
Who said Condenser cam?
I said a condenser can...
Usually when toy have manual points, these is a capacitor (Known as a condenser) which (I think) helps give a better spark. The two are usuely replaced at the same time. I have had a failed condenser back in my poor student days which took ages to work out!
Where’s Chas been?
ECU or Points?
Loving the pictures Matt It's a cool looking project and I look forward to seeing more progress!
I have to say though that I went when I saw you taking a hacksaw to the dashboard! Is there no way you could get it out without cutting it? It's quite flexible and pulls UP from the mountings so you may just have been able to squeeze it past the roll cage. Talking of which, is the the roll cage bolted or welded in? If bolted you might have been able to unbolt it and move it back a bit just to get the dashboard out.
In case you're wondering I love the mk1 dashboard so if the RSF car were mine I'd do everything to keep it in one piece! Bit late now though as you've cut yours out, but there should be a few available from broken up mk1s if you ever want to put one back as it's one of the few bits of a Uno that won't rust
As for wheels, there are loads of cool wheels available in 98 PCD. You also had those gorgeous Cromodora wheels fitted if I remember rightly - what happend to them?
Hurry up and finish your exams and get cracking on this little racer
first of all, nice project
if you got an electrical pump, that would flood the carb with gas, and that would mean that the car wouyld need much revs and air to at least run, and it would go spitting and misfireing because of all the fuel. the pressure in the fuel system of a car with a carb (after the mecanical pump) is about 0,2 - 0,3 bar.
the 1301 ccm with a 30/32 dmt weber carb has a manual choke. and no, it would ot cause a misfire, but it would help the engine run on lover revvs when cold. it could actully help to drive the car for a while, some problemes with engines can come from just the driver doesn't drive the car hard enough.
the condenser is sort of a battery, which is connected in parallel with the points (?) and the only thing it does is to make sure that when the points open the circuit is broken instantly. because these things happen really fast, as an example, when a four sylinder engine has 3000 revvs, there is 6000 sparks per minute, that means 100 sparks in a second
so the condenser is only helping the points breaking the primary circuit in the coil instantly.
hope you understood what I ment, a little hard to find the right expressions since I'm a norwegian
Sorum91
oops, seeems I a little bit to tired, didn't see the other pages
and be a bit carefull with too strong bulbs, a 100w would melt the reflectors since the are made of plastic
few! glad i got some posts, it was getting a bit lonely in here!
thanks mate
the fuel pump has a pressure limiter after it, and i think it is set up to have a by pass valve at a certain pressure - whatever it is it was set up by wolf direct racing who know their **** backwards, upside down and asleep - so i trust them.
The choke has been completely removed off this car - being a racer i guess they just had no use for it..
thats for the explination but i looked it up after louie said what it was, now i know...and dont worry your explination (and english!) is very good
yeah im getting rid of the 100w bulbs - they are WAAAAY too much hassle, and totally the wrong way to go for the uno if your looking for brighter lights
cheers guys
wouldn't it be twice that many sparks as all 4 cylinders fire each cycle of the crank. because these things happen really fast, as an example, when a four sylinder engine has 3000 revvs, there is 6000 sparks per minute..
