ralphnz
- Jul 18, 2008
- 124
- 35
Howdy
Gasket went on a 999 FIRE. Took off the head, no warps, or damage. The head bolts were bolted down unbelievably tight. Way way tighter than the specified torque. The gasket was broken (wire bit) on cylinder 4. However piston 3 has damage to the outside edge, and correspondingly, on the cylinder wall at the top were deposited/stuck hard, non-magnetic shards, almost matching the damage in the piston. My question is, are these from the cylinder seizing at some point and the bits breaking off the piston, or are they broken rings. I am not sure how the car was running before it overheated, so don't know what the compresion was on this cylinder. Is there any way of knowing what it is, and should I just put the lot back together with a new gasket and see how it goes?
