General Uno Turbo coil springs onto a Uno Cento
UnoCento:)
Johannesburg
Hi
If i took uno turbo coil springs and fitted them to my Uno Cento would it make any difference with handling and ride height? and is it worth me buying and fitting them?
JW(y)(y)
Hi
JW(y)(y)
I'm not sure if your Cento has a FIRE engine or a 1372cc engine?
Lowering springs for an Uno Turbo will have little effect on a FIRE-engine Uno and will probably even raise the front (standard Uno Turbo springs definitely WILL raise the front, due to the decreased weight of the engine/gearbox of the FIRE compared with the Uno Turbo).
There is less difference between the weight of the 1372cc engine/gearbox and the weight of the Uno Turbo engine/gearbox. So if you have a 1372cc, then I'd say that 40mm Uno Turbo lowering springs would be a safe choice. My Uno Turbo has Koenic (note the 'c') springs, made in South Africa (not to be confused with Koenig German springs). Really good value for money and do exactly what they say on the box.
-Alex
