If you need a hand with anything just give us a shout. i know ut inside out bar the gearbox.
dont worry to much about your engine, bad 1s normally leak lots of oil due to pressurization of the sump.
this happens when the rings are excessively worn. valve sills, and worn exhaust valve guides are likely to be the culprit of oil leaking in to the combustion chambers.
