- Sep 2, 2007
- 126
- 112
Hi there,
Had an unexpected problem last night as I was reduced to driving my Mk 2 Uno on sidelights only for a short distance! Turning the headlight switch to the second position (dipped beam) had no effect at all although main beam is intact on both sides.
Checked individual fuses-all are OK and changed bulbs but no difference. I've also managed to substitute a second column switch assembly unit but with the same result.
Then I remembered going back a few years that this had happened before and turned out to be a faulty interior fuse board :idea: . I'm going to move the wires around behind the fuse board to see if this makes any difference in the dipped beam position on either side, but any other help/advice appreciated.
Cheers,
Andy
Cheers,
Andy
