The left side door opener just pushes in and doesn't open the door,I have the door panel of but cant seem to understand the fault, any tips?
The door opens from inside ,can see the mechanism move on both levers ,only the outside handle doesn't open it, I will try to take it out as you say and inspect.
I have taken the lock mechanism out ,but the outside opener doesn't seem to work ,only when i help the mechanism arm to move far enough.,gotta get a new one i think, but no one here has them
Or maybe you can just bend something a bit... Big slip-jaw grips and giant screwdrivers come in handy.
On the 5-dr Uno, the handles I've seen have an adjustable screw/locknut that sets the pressure applied to the lock mechanism. I guess you would have noticed this - or perhaps you have a 3-dr?
-Alex
by the way, Can I switch the door key hole (lock cylinder) with the one on the right side? ,as the previous owner destroyed the left one (drivers side) I must go around the car all the time to unlock.
