Thread Tools
Old 07-07-2008   #1
Electrical - "services" fuse being blown often
Hi. I own a secondhand Uno (1994)which has had accident damage in the past. The "services" fuse gets blown often, causing things like rev counter, fuel gauge, idling, indicators, brake lights, etc to stop working immediately. It seems to be triggered when my left hand indicator is activated, but not every time. I checked the wiring at the front & back indicators, also inspected indicater switch - no visible problem. A 15 amp fuse did not blow (normal 10 amp) but started melting the plastic - not a good option! Can anyone help please?
Gerhard is offline Reply With Quote Quote
Old 07-07-2008   #2
ShoeBox Turbo 1.4 I.E
BillyTheKid's Avatar
BillyTheKid has donated!
Re: Electrical - "services" fuse being blown often
i had the same problem with my coupe and it was down to water leaking from the windscreen seal onto the fusebox. try swapping the fusebox if u can and check above/behind it for leaks.
Can You Keep Up? Baby Boy?...
BillyTheKid is offline Reply With Quote Quote
Old 08-07-2008   #3
Chas Uno has donated!
Air Dodge Champion, Asteroids2000 Champion, Frogger Champion
Sounds to me like a short circuit somewhere or a bad earth. Check that all connectors are pushed in fully, including the ones on the back of the fuse box. Also check that the earth connections for the front indicators are clean and secure.
Quote Originally Posted by Trinity View Post
we got a lot 126 here in Egypt .. a funny car and fun to drive though sometimes i feel like I am sitting on a chair in the middle of the street
http://onastick.net/drew/sinistar/
Chas Uno is offline Reply With Quote Quote
Old 08-12-2008   #4
South Africa
Wink Re: Electrical - "services" fuse being blown often
okay dude...one thing you need to do chech you ignition wiring at in you steering are. i found that my fuses kept blowing ase the wiring was burning out at the ignition and the wires crossed and kept burning out the fuses. i had to rewire and the problem stopped.
polerafon is offline Reply With Quote Quote
Old 08-11-2018   #5
South Africa
Had the same problem but it just stopped. Think it could just be a defect. Found a bunch of 10 fuses hidden all over the car. Mine is second hand. I've just keep a bunch of fuses in the car. There's even slots at the bottom of the box for spare fuses
Melz17 is offline Reply With Quote Quote
Thread Tools
(G) Were's the fuel pump relay/fuse "Um on an Uno" Stuartl Panda (Classic) 7 04-05-2007 20:26
"bashful bowel"? "shy bladder"? Jai Leisure Lounge 3 10-11-2006 16:07
(T) Dash display from a "SX-ELX" too a "S". Can you? Basedk Punto (Mk1) 6 07-07-2006 16:05
Whatever happened to "dweebs" and "nerds"? CinquePunto Leisure Lounge 18 03-02-2006 19:25
