- Sep 2, 2007
- 126
- 112
Hi everyone,
Had a bit of a scary moment yesterday when my Uno 60 1108cc 'J' reg 1992 car cut out suddenly at 50mph on the M18 (it had also happened a few hours before on the way to Bawtry, again at around the same speed).
In the first case, the car would not restart for about 10 mins (turning over but not sparking) but then seemed normal (although I was on minor roads travelling a lot less fast), until the problem reappeared on the motorway.
Slight spluttering before total cut out each time. Dash ignition lights only came on when car had slowed considerably so possibly not an electrical fault? Not been an issue so far at slower speeds. Fuel left in tank! New fuel filter was fitted about a month ago and perished fuel pipe changed. No fuel leaks evident. Temperature gauge normal.
My vehicle uses the single point injection system and I'm wondering if the fuel injector is blocked/gummed up or if the fuel petrol pump is starting to fail, but only when it is being worked hard at high speed.
I'm considering whether to add a treatment to the petrol tank to help clean the injector or change the pump itself.
Has anyone ever experienced this kind of problem and found a solution?
Thanks,
Andy
Thanks,
Andy
