Thread Tools
Old 10-07-2004   #1
fiat uno headlights
Having problems getting the headlights in my 1992 fiat uno chic to work.
when I flick the switch for the head lights I here the relay click but nothing happens I've changed the relays by the passenger side front door and checked the fuses.
when i flick the switch down to full beam I can then turn the fog light on but the main beam lights don't come on.
I've connected a wire to the battery and one to the lights... they all come on.
I guess the problem lies between the fuse box and the lights.
Anyone got any ideas???
Thanks for your time
Rob
rob123 is offline Reply With Quote Quote
Old 14-07-2004   #2
Chas Uno has donated!
Air Dodge Champion, Asteroids2000 Champion, Frogger Champion
Have you checked to see it there is voltage at the wiring connections to the headlights? It could also possibly be an earth problem, so check all the earth leads from the headlights. It may also be a faulty light switch, so if possible try and subsitute it for another. Other than that, you just need to work through the wiring to isolate the fault.
Chas Uno is offline Reply With Quote Quote
Old 28-08-2007   #3
Re: fiat uno headlights
Slight revival...
My driver side main head light bulb comes on but is faint. I swapped it for the passenger side one with the same result.
However, both bulbs are very bright on the passenger side.
All help appreciated ;-)
Kalel is offline Reply With Quote Quote
Old 28-08-2007   #4
Trader Rating: 1
clean all the collection of earths to body under the battery tray, you may need to renew some of the wiring, i started on the fan connections and ended doing nearly all the wires under the bonnet, Ant!
antsuno2 is offline Reply With Quote Quote
Old 29-08-2007   #5
Tell me about it! You start with cleaning one bit and then you end up taking apart most of it to renew it all.
Headlight now working nicely!
Thank you
Old 26-05-2010   #6
South Africa
thanks Ant - I have just cleaned the connector stubs with a needle file (may have to use glass paper inside the clips) and indications are positive - will test tonight.
I have been driving with lights that don't always work for more than a year even though I have had the controls (that sit on the steering wheel) replaced.
so...
thanks again
StephanoQ is offline Reply With Quote Quote
Old 26-05-2010   #7
South Africa
Lol ya, the headlight dimming thing is a common thing with my uno, I have to clean those connectors every year. Works every time.
Hyperspace is offline Reply With Quote Quote
Old 3 Weeks Ago   #8
South Africa
Hi guys I know this the old thread but am experiencing the same problem my lights were working just fine until the other day when they disappeared completely no headlight main beam nothing. Now I can't drive at night please help me what should I look for? Everything is working fine the indicators are there,hazards etc.
tumi1986 is offline Reply With Quote Quote
Old 3 Weeks Ago   #9
Iggy64 has donated!
Iggy64 is an honorary friend of the forum :)
I think most of the answers are there in the previous posts. My approach would be to go systematically through all the connections from main switch to the lights themselves and try to find the point on the circuit where there is no power. It could well be the switch itself as both lights have suddenly failed. Do the rear lights come on or is everything worked by the switch dead?
Iggy64 is offline Reply With Quote Quote
Thread Tools
Discounted Tuning @ Fiat Forum Day alfanige Lets Talk FIAT 45 17-01-2006 14:03
MODELS FIAT SHOULD MAKE! jetweed Lets Talk FIAT 61 30-08-2004 21:38
FIAT UNO N/Offside HEADLIGHTS/ INDICAT ..E-BAY Boz Auction Watch 0 26-04-2004 16:24
(G) Fiat Bravo (moved thread) sonia cachia Bravo / Brava 7 20-10-2003 04:30
