Old 17-08-2007   #1
Scale for economic consumption
Hi,I have Fiat Uno 1.0 FIRE 1989. and scale for economic consumption is always on right side,it`s stuck...
I`m from Serbia and I need your help...
Thanks in advance
nando is offline Reply With Quote Quote
Old 17-08-2007   #2
Chas Uno has donated!
Air Dodge Champion, Asteroids2000 Champion, Frogger Champion
Re: Scale for economic consumption
Quote Originally Posted by nando View Post
Thanks in advance
Ah, the wonderful 'econometer'!
First of all, does the gauge only go to the right side when you turn the ignition on? Does it go back to the left when you turn the ignition off?
If it does, then the gauge is fine and it will be the sender unit that isn't giving out a signal.
You can find the sender unit for the 'econometer' in the engine bay, next to the coil. It will be located on the top suspension mount plate. Look at the right hand side of the picture below and find the coil. The econometer is just behind it (not really visible in the picture though).
Find the sender unit, and check to see if it has a wiring connector plugged in and also a vacuum pipe connected to the top. The vacuum pipe connects to a 'T' piece in the pipe that goes to the brake servo. Sometimes the vacuum pipe comes off from one of its connections, which makes the gauge stay on the right like you mentioned. Also make sure that the vacuum pipe isn't damaged in any way, and isn't leaking.
You could also try disconnecting the vacuum pipe from the 'T' piece and leave it connected to sender unit. With the ignition switched on, suck the end of the pipe and ask someone to see if the gauges registers anything. If it does then the gauge and sender unit are fine.
Good luck!
Quote Originally Posted by Trinity View Post
we got a lot 126 here in Egypt .. a funny car and fun to drive though sometimes i feel like I am sitting on a chair in the middle of the street
http://onastick.net/drew/sinistar/
Chas Uno is offline Reply With Quote Quote
Old 19-08-2007   #3
Thank you so much!Wiring connector was totally out of it`s position and I didn`t see that!Thanks again!!!
Old 19-08-2007   #4
Always a pleasure to keep another Uno running sweetly
(G) Too big fuel consumption hcampian Panda 1 30-03-2007 09:30
(G) New Ulysse Diesel 2.0JTD terrible poor fuel consumption leeboy Ulysse 59 11-11-2005 05:40
(T) Onboard computer - Instant consumption radicool Punto (Mk2/2b) 9 15-12-2004 21:15
(T) JTD (115BHP) - Low Fuel Consumption lostsoulal2 Stilo 29 03-06-2004 03:20
(G) consumption: temperate vs tropics baslaityer Ulysse 18 15-01-2004 09:46
