Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->How To: Making Custom White Dials<!-- google_ad_section_end -->
Published by charlieboy
30-05-2005
Unrated
User Rated:Unrated
Making WHITE dials for your UNO
You will need:
  • Pictures of old dial faces (to scale)
  • Photoshop (or similar programme)
  • PC/laptop (obviously duhh)
  • Paper & printer
  • Spray glue
  • Scissors/Stanley knife/Scalpel
Obtain photos of old dials – dismantling of old cluster may be needed so take extra care not to break the needles or other parts!! (see next page for ready mades)
Open photo shop, click the “open file” button and open the photo of the dial (Speedo, petrol or temp.)
Zoom in on the image till it is big enough for you too see clearly, then using the “Magnetic Lasso Tool” begin to outline the dial (around the black area). Once this is done the dial will have a flashing black and white line around the area you have outlined.
With the dial outlined you can now make it white. Click “Layer” on the task bar, the “New Fill Layer”, “Solid Colour…”
The “New Layer” box will appear when you click “Solid Colour.” There is not really any need to change the name of the layer, on the drop down bar select “Exclusion” then click “OK”
The “colour Picker” appears on screen now, select your chosen colour. In this case being white. And then click “OK”
The dial has now changed to white. Print out onto white paper (should be to scale). And cut out using the necessary method. To mount the dial you will need spray glue and then jus simply mount them over the existing dials.
CAUTION: when mounting new dials make sure that they line up with the old dials. This can be done by turning the key (on temp/petrol dials) the needle rises, make note of where it is (as best you can) turn ignition off. Place on dial and turn key, needle rises, adjust till correct. With the speedo the same will need to be done with AS MUCH CARE AS POSSIBLE as you don’t want this dial to be inaccurate!!
If you wish to experiment with different colours “Undo” (CTRL + Z) the colour change and go to “Layer”, “New Fill Layer” and “Solid Colour”. “New Layer” box, drop down menu bar “Exclusion”, “OK”. “Colour Picker”, select the desired colour and “OK”. Dial changes to the colour you selected (to match/contrast/or ‘cause you liked the colour. The choice is yours!!! If you have more advanced skills add a design/picture of you choice.
My PS skills are only just developing, this is a rough guide of how mine were done! Have fun and enjoy your new dials!!
Charlie
*Thanks to LOUIE BEE for the photos of the original dials, to scale! They can be found in his photo gallery here on FF! Cheers buddy! *
Contents
<< <    Next Page: Sample Dial Photos (Page 1 of 2)    >  >>
Old 31-05-2005   #1
Trader Rating: 16
beau has donated!
Re: making white dials - the guide....
no one has thanked you for that, so i will
Maserati 3200 GT Coupe
beau is offline Reply With Quote Quote
Old 04-06-2005   #2
Slovenia
Ok. i got the dials printed out and everything but now i dont know how to take apart the dashboard. i still dont know what mk is my uno mk. 2 perhaps?! so here is the pic of the dash.
dashboard
tnx
ToMi` is offline Reply With Quote Quote
Old 04-06-2005   #3
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Louie Bee has donated!
Rollin X Pinball Champion, Bubble Bobble Champion
Mozambique
Hi ToMi`,
You have a MK2 Uno there, but it’s not the same the UK one as there is no temperature gage.
This is the UK MK2 base dash – but don’t worry, you don’t need to remove the steering wheel – I was fiting in a Turbo wheel when I took this picture.
There is a rough guide on post 10 in this thread, https://www.fiatforum.com/uno/31796-rev-counter.html
Ignore the bit about the tachometer wire, as you won't need it . Let us know if you get stuck.
The petrol gage is different in your Uno, so you may need to scan yours in. They are held in by only 2 nuts. I scanned both gages in without removing the pointers BTW. Please post the original picture if you do it
Good luck
Regards,
Louie Bee is offline Reply With Quote Quote
Old 04-06-2005   #4
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
very good guide!! you should post this in the general forum as its easily used on other models
Old 04-06-2005   #5
Slovenia
tnx for the info! i have the right dials scanned so that's no problem .. i'll read all about it and have a go tommorow morning.
Old 04-06-2005   #6
Trader Rating: 4
"you should post this in the general forum"
louie will you move it please, me a bit unsure bout doin it
chalrie
For Sale: BMC CDA, see classifieds!
Quote Originally Posted by KoArAnG
Black wheels and silver cars are yummy
< Team Anthracite >
charlieboy is offline Reply With Quote Quote
Old 04-06-2005   #7
Trader Rating: 1
Luke has donated!
George Wants Beer Champion, Home Run Champion
if anyone isnt too good at photoshop, but has some good ideas - send me the graphic of the dial and your idea and i can do them
Luke is offline Reply With Quote Quote
Old 05-06-2005   #8
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
thanks for asking
I discussed it back stage with other mods, and it seems this thread is most relevant to Uno Styling, and will be staying put.
As much as I'd like you to get an Uno if you don't currently have one,
Your welcome to keep your eye on The Uno Forums for more top threads LOL.
Louie.
Old 10-06-2005   #9
Trader Rating: 4
on the turbo dials are the "temp." "petrol" and "speedo" the same as on the normal uno?
if they are different does anybody have any they could scan onto their pc, to scale ??
charlie
< Team Anthracite >
Old 01-09-2005   #10
Quote Quote:
How do you know the right size in paintshop to have it to scale as you imply
nay27uk is offline Reply With Quote Quote
Old 02-09-2005   #11
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
Go for the larger files in this gallery
https://www.fiatforum.com/gallery/sh...ry.php?cat=638
They are already in scale
Old 04-09-2005   #12
thanks louie bee but they are not for a mk1 do you have any for the mk1
Old 04-09-2005   #13
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
Sorry - I have no MK1 dials
I dismantled my old pod and scanned the dials, copied and pasted into Photoshop. They print exactly the right size .
Old 05-09-2005   #14
ok louie thanks for your help, when i get some time i will take mine apart and post up the pics for other mk1 owners
Comment
Search this Guide:
(S) White Dial's ne1l Punto (Mk2/2b) 12 02-02-2007 20:07
(S) white dials for a fiat brava 1.2 16v bravaboy Bravo / Brava 5 19-12-2006 15:48
(S) White Dials cm246 Uno 2 13-02-2005 07:25
(G) uno 45 white dials..help burbo Uno 0 05-01-2005 22:46
(S) white dials..? peterp Bravo / Brava 7 11-06-2004 19:50
