Technical Tipo 1.4 T-Jet Fuel Filler problem
Phobion
Hello Everyone!
Does your Tipo has this 'hole' on the fuel filler? Today I went to the gas station to refuel and then I noticed that a lot of petrol coming out from the bottom of the fuel filler. :confused:
Hi :)
Ive just been out to see my only FIAT with this capless system - @2013 panda
Its a METAL feature..
Not a split.. my guess is its either the Overflow..or a Breather of sorts..
How full does the fuel gauge indicate?
Hi :)
Thank you very much Varesecrazy! I guess then it was something else, I'll refuel a bit after 1-2 days at another fuel station and we'll see.
'How full does the fuel gauge indicate?'
It shows that the tank is full.
Hello Everyone!
Definitely not that looks like a cracked or damaged area on the filler
Edit just had a look at my car at it does have this area but it's in the area before the flap on the filler nozel
So if the pump is fully inserted there should be no fuel coming out of there
