Old 07-06-2021   #1
Spare wheel retaining bolt
Hi all,
I have just bought a 2017 Tipo estate. The full sized spare wheel is held down, through the tool kit, by a retaining bolt. The bolt is held by a moulded plastic part, that is supposed to undo the bolt when it is itself turned. This one just spins around the bolt, I guess the plastic has rounded off. There isn't space to get a socket in.
Has anyone else experienced this? Has anyone an idea to over come it? or am I being an idiot and have missed something obvious.
This is my first post on a forum, but please don't worry about sparing my blushes......
Stevecoles is offline Reply With Quote Quote
Old 07-06-2021   #2
varesecrazy has donated!
Quote Originally Posted by Stevecoles View Post
Hi all,
Hi and welcome
I had this on my sons Grande Punto..
I found that the wheel wrench drove the plastic handles hexagon around the bolthead quite well..
Bottom of the thread was rusty..
Likes Stevecoles liked this post
Old 08-06-2021   #3
Re: Spare wheel retaining bolt
If you look under the back, in the middle of the boot floor you will see the thread sticking out, unprotected and rusting nicely. I gave mine a coat of protective grease to make sure you can get it out in future. Because 11pm at the side of a road in minus 2 in a blizzard is not the time to find out your wheel is stuck.
Thanks uksdsgl, Ralf S. thanked for this post
Batius finkius is offline Reply With Quote Quote
Old 08-06-2021   #4
Thanks for your reply. Yes, I found I could easily turn the plastic handle using the wrench, but it is just spinning around the head of the bolt, without undoing the bolt.
There isn't room between the plastic and the bolt head to get a socket in.
Am I going to have to cut the plastic handle in half to get to the bolt?
Old 08-06-2021   #5
chris3234 has donated!
Perhaps some mole grips on the underside on the bolt to loosen it as much as you can
Should hopefully get enough moved to free it up
chris3234 is online now Reply With Quote Quote
Old 08-06-2021   #6
Good idea, I'll give it a try.
Old 08-06-2021   #7
I had the plastic spread..and jump over the corners of yhe bolthead
The ( 17mm?) Socket held it together enough to free it off.
If you are using molegrips..
Grab the bolt head.. even if pinching the plastic against the bolts hex..
Better than mangling the thread.. and having other problems
(G) Brake caliper retaining bolt dimensions Robearl1977 Grande Punto 7 27-11-2020 14:54
(G) Spare wheel securing bolt size?? JoshV Grande Punto 13 24-11-2014 18:11
(T) Spare wheel & spare wheel carrier for 2011 Ducato 15" gullrock Ducato 4 03-10-2011 19:15
(G) Anyone got any spare rear shoe retaining clips? corky Punto (Mk2/2b) 3 01-10-2011 14:32
(T) Steering Wheel retaining nut jandi Punto (Mk2/2b) 3 13-12-2009 17:48
