As some of you may have seen from another post I changed the rear shocks due to one leaking
Was rather surprised how rusting the threads of one of the lower bolts was
Strangely the other side was nearly perfect cleaned it up a bit then gave them both a good coat of anti sieze paste so should be fine for a few years now
The 2 top mounting bolt to the body were also perfect other then having to cut a bit of the arch linear out of the way to get acccet to the bolts
(Great idea there designers having to take the how linar out to get to two bolts)
