Would anyone know the general route of the rear washer pipeline. Mine has ceased to supply water to the top of the tailgate on my Tipo estate and l can hear (but not as yet see) the water running / rushing out somewhere in the nearside bulkhead area...l suspect that a joint has popped or pipe split somewhere in this area due to the freezing weather. I can't unfortunately see clearly or get my fingers to it but the supply pipe in the engine bay seems to disappear between the engine fuse box wiring loom bundle and the bulkhead, just where loom attaches to the bulkhead. Where could it go from there, I wonder? Do I pop off the plastic fascia panel over the suspension turret s / around the windscreen wipers or consider a look behind the glovebox area? It wouldn't be taped into, and fed though with the wiring loom, would it? The pipe, when it gets into the cabin must surely go up one of the A pillars along the head lining to the back of the car... I should investigate further when conditions are better and I have the enthusiasm, but just where too look... There is also the thought that the screenwash is flowing to some unintended & hopefully non electrical place every time I test it! Any thoughts welcome, thanks!
