MoneyPolice
- Apr 23, 2009
- 30
- 19
Not sure whether it's the recent cold weather here in the UK, but the rear window washer on my 2017 Tipo Station Wagon doesn't work. The front washers are fine and I can hear the pump working when I try to wash the rear window. The bottle is full, I always use a screenwash and I have cleaned the nozzle over the rear window. One thing I have noticed is that, if I operate the rear window washer for between 5-10 seconds, water start to run out from somewhere in the engine bay and comes out on the floor. Could this simply be the pipe to the rear window is frozen and the pressure is causing the water to back up? I haven't used the car for over a week before yesterday. Could a pipe have become unattached from the pump and if so, where should I look? Many thanks.
