Thanks for the info on the wheel sizes/spares JTD. With my boy's budget it's likely to be quite an early example we'll be looking at and unlikely to be a top of the range spec - we would prefer not to have the larger diameter wheels with their low profile tyres so maybe it will have a full size spare.
I really do hope we like this car when we eventually get a test drive - luckily there is no pressure as the Astra is still going Ok - There is just so much about it which appeals to me.
I've been browsing videos on you tube and came across one which showed a turbo and exhaust manifold with cracks in them. It said that this was a not unknown problem with them, anyone know if this is a substantial problem? I wonder too if there is any appreciable turbo lag? (I ask because my Ibiza has this when pulling away from low revs. I notice it especially when accelerating away from speed bumps.) I do very much like that the engine is a cast iron "lump" of well proven design with not too much by way of complicated "features". Simple MacPherson struts at the front and a torsion beam rear axle does it for me too. No electric parking brake too! I don't see much reference to "silly" features like automatic city braking either and I like that cruise control seems to come on all but the base version? By the way, do you have to push the clutch to the floor to operate the starter?
I'm not a lover of "infotainment" in cars so the fact that the screen is rather dated doesn't worry me at all - my boy's never had a car with one so he won't know what he's "missing".
The one factor that seems to be defeating my "master plan" is that there don't seem to be many T jet estates for sale in the used listings and I actually can't find one at all up here anywhere near to us!
Mid spec Easy Plus has a good spec like air con, touchscreen with DAB, Electric windows all round, remote locking and electric mirrors, and 16" alloys, without the extra niceties like auto lights and wipers, climate control, 17" wheels and sat nav of the Lounge model. The small 5" touchscreen was replaced with the better 7" one from late 2018 on mid & high spec Tipo's (Easy and Street models kept the radio without touchscreen throughout) but it took a while to filter through due to older stock cars hanging around.
I've not seen any reports on here about the manifold. I guess it must've happened at some point to get onto YouTube, but given how widely used the T-Jet engine is, I'd have thought it'd be showing up on here and other owners forums like Multiair issues, if it were particularly common.
My 2018 T-Jet only asks me to press the clutch if I turn the ignition on when it's left in gear. I tend to press the clutch regardless to reduce effort on the battery etc, but it must only ask for it on some models or years.
There's barely any lag at all on the T-Jet providing you're not a couple of gears wide of where you need to be, and even then it doesn't make a lot of fuss providing you're patient! If you struggle with finding the T-Jet then the diesels are not particularly problematic as far as DPF are concerned. The 1.6 diesel is very torquey and you almost row it along at low speeds because of the sudden shove of power. The 1.3 diesel is obviously not going to go like the 1.6 or even the T-Jet, but having used the engine in other vehicles it's probably a better bet in a Tipo estate than the 1.4 95bhp, which having driven in hatch form I can imagine will feel inadequate, especially when loaded up.
Gearbox issues will depend on the unit used. If it's the same as the Alfa Giulietta with the T-Jet and 1.6 diesels then it'll be occasionally obstructive (especially in 1st and 2nd) but largely fine up to higher mileages. The only recent common(ish) issues I can recall are on MiTo, Bravo and Stilo models with the 1.4 16v 95bhp engine and associated 6 speed box which can self destruct after a while, but as I don't think that box is suitable for the more powerful engines I don't think it'll be used in the Tipo beyond the base 95bhp petrol, if at all.
