FIAT Auto Specialist Team
Old 15-10-2020   #1
Question fiat tipo driver side electric window
is this an easy fix and do I take it to a fiat dealer or can any garage do the repair
billmo21 is offline Reply With Quote Quote
Old 15-10-2020   #2
chris3234 has donated!
Re: fiat tipo driver side electric window
Depends what's wrong with it?
But electric windows are virtually the same in all cars these days so you local mback street garage should have no issues with them
chris3234 is offline Reply With Quote Quote
Old 15-10-2020   #3
I Think its the glass because of the sound it made and the electrics still work when I press the the button but it does not come up
Old 15-10-2020   #4
2014 PANDA 4x4 TwinAir
MaxHeadroom's Avatar
MaxHeadroom has donated!
Hello Billmo and welcome to the FIAT forums.
Sorry to hear you have had an issue with a mirror. As Chris said, most elecric mirrors are of a similar set-up.
My SAAB ones were held in with a piano-wire- spring. I've found others are simply bonded in with a kind of two-sided adhesive tape. Having said that I'm not familiar with how FIAT ones are.
Have you tried gently 'assisting' the mirror with your hand as you motor it back up? Could be the mirror glass has become detached and is jamming. I've had similar snags that have 'fixed themselves' probably due to some dirt or debris in the works
_____________________
In the North Cotswold hills
MaxHeadroom is offline Reply With Quote Quote
Old 15-10-2020   #5
varesecrazy has donated!
Quote Originally Posted by billmo21 View Post
Pretty sure its been mentioned on here before..
SEARCH is good
varesecrazy is online now Reply With Quote Quote
Old 15-10-2020   #6
Old 16-10-2020   #7
Italian Stallion
twincamms has donated!
I know this is a little off topic but I have a question, when I press the button to wind my drivers side window up/down it's one press and the window continues to move until you press to stop, the passenger side doesn't do this you have to keep your finger on the button, can this setting be changed to match the drivers side?
Thanks.
Thanks chris3234 thanked for this post
twincamms is offline Reply With Quote Quote
Old 16-10-2020   #8
Quote Originally Posted by twincamms View Post
Thanks.
Unfortunately not at least if there is nobody has found a way of configuring this
It may be possible via some sort of custom proxi configuration but there's a lot of riskh with that
Old 16-10-2020   #9
Any progress?
Old 17-10-2020   #10
Italian Stallion
Nope.
(T) Fiorino driver side electric window problems Deedge Fiorino (Mk3) 2 17-06-2020 23:31
(T) Driver side electric window jeffridj Bravo 7 11-07-2013 10:32
(G) Driver side electric window switch Pea6969 Grande Punto 7 08-05-2013 22:36
(T) Driver side electric window Olof Larsson Bravo 10 08-04-2009 16:09
Driver side electric window Gspot FIAT Boo Archives 2 10-09-2004 09:14
