Technical Start & Stop is unavailable
Phobion
Hello Everyone!
Today for the first time when I stoppod with my 1.4 T-Jet Tipo (no shutdown just stopped, Start & Stop was disconnected) the car showed 'Start & Stop is unavailable' message and the only way to start the car was to turn off with the key and then turn on with the key. I pressed the Start & Stop button, clutching but nothing helped. I always turn off the Start & Stop. Should I contact the services with this? No stored alert messages, the car has only 3457 KM. :confused:
Best regards
The same thing happened to me.
I have recently had my batery level sensor replaced under warranty, which was showing a wrong battery level charge and this was preventing my start-stop from working. This sorted the start-stop and it was working fine.
Only a few weeks later, I had the same message pop up (start stop unavailable) a few days ago.
I've also got a 1.4 T Jet with similar mileage to yours.
Could it be because there is insufficient charge on the battery?
Would welcome advice from others on this - Thank You
