Hi all.
Having got my '17 Tipo (1.4 95ps) in November last year immediately I took it to Fiat to resolve a whine in 6th gear.
I went out with the technician who basically said he couldn't hear it (on the world's worst roads around the dealer).
The noise kicks in at lower speeds but was noticeable only in 6th...i.e at 40-55mph.
Anyway they said if it persists bring it back.
Funnily enough it persisted so I did. This time they acknowledged a noise that shouldn't be there and I am told they replaced;
Clutch
Flywheel
6th gear bearings.
I got it back and the noise was still there, although I could tell they had changed the clutch as the bite was different.
I ran around like this for a little while until I needed to take a long journey in which it started getting very notchy between 5th and 6th.
Back we go for the third time, this time they advise a complete new gearbox will be fitted.
1 week later the car gets delivered back to me and..what's this? It won't go into 5th / 6th gear at all!? The guy who drove it back was keen to go funnily enough.
So off it goes a fourth time... Again the gearbox as fault apparently, so they order another one in from Italy. I get it back and the service manager tells me to "caress" it into 6th because if you bring the stick too far to the right it can catch the gate !?! Never did when I first got it....
Having driven it a while today I've decided I'm still not happy for two reasons:
1) ...Still a whine in 6th gear which makes me think it's driveshaft or engine related?
2) It's actually quite difficult to shift between 5th and 6th without "catching the gate". It has to be a perfect linear shift and whatever you do don't change mid corner. It's easy to miss and struggle to get back into either gear. Now I highly doubt anyone elses Tipos are that delicate between those gears?
So given that I don't feel the issue has been resolved satisfactorily I'll be going back to the dealer to have a 5th attempt at. I might get laughed out of there or have no leg to stand on, so would appreciate feedback from other Tipo owners regarding their gearboxes in regard to the issues I've had.
Apologies for the ramble / rant.
Thanks in advance
Clutch
Flywheel
6th gear bearings.
Thanks in advance
