Thread Tools
Old 4 Days Ago   #1
idel speed fluctations
had a issue this morning after setting off drove short way to main road and stopped to get out and the idel speed was changing between 800 and 1000 ish while sat there out of gear engine was still quite cold but warm enough that it had dropped from "warm up speed"
any idea what the issue was?
Cal2412 is offline Reply With Quote Quote
Old 3 Days Ago   #2
Re: idel speed fluctations
any ideas its done this again today really annoying
sound like its running perfectly fine just like somebody is reving it a small ammount?
Old 3 Days Ago   #3
Hi Cal
To help you get a bit of useful help it would be helpful to advise what age and engine/fuel type you have. the mileage and some history of the care the car has had will be useful too.
Tim
timmycm850 is offline Reply With Quote Quote
Old 2 Days Ago   #4
chris3234 has donated!
He has the 1.4 16v same as me if my memory is correct
chris3234 is offline Reply With Quote Quote
Old 2 Days Ago   #5
as above its a 1.4 16v with 39k miles
Old 2 Days Ago   #6
Once its warmed up, it's back to normal?
barnettgs is offline Reply With Quote Quote
Old 2 Days Ago   #7
Quote Originally Posted by barnettgs View Post
yeah it runs fine once warmed up
the issues only seems to show when fairly cold
Old 2 Days Ago   #8
Quote Originally Posted by Cal2412 View Post
I think its normal for engines to do that when it's cold.
It doesn't affect when driving from cold, is it?
Old 2 Days Ago   #9
normal? since when is normal for the idel speed to alter around 100rmp every 2-3 secsonds its never done that until reacently and never haerd of any other car doing it
Old 2 Days Ago   #10
Czech Republic
I had same issue. Dealer just replaced sparkplugs and its gone.
Obo67 is offline Reply With Quote Quote
Old 2 Days Ago   #11
Quote Originally Posted by Obo67 View Post
sholdnt be spark plugs fitted irridum plugs and they have only done 3k or so
Old 1 Day Ago   #12
I suppose spark plugs are the only one that were changed recently? It could be that they behaved a bit differently when cold? Brand name?
Not all spark plugs are same but someone with more knowledge can help you.
Idle normally goes up to around 1000 rpms or so, when starting cold regardless of which car.
By the way, it can be a concern if it is idling roughly.
Old 1 Day Ago   #13
ngk 6046- DCPR7EIX plugs were fitted
and im not talking about the increased speed at warm up
the idel speed it contstantly changing eg 900 one sceond then up to 1000 then back to 900 a sec later allmost like the throttle is being pressed a small ammount
Old 1 Day Ago   #14
Romania
Dismantle and clean the throttle valve.
aschiuta is offline Reply With Quote Quote
Old 1 Day Ago   #15
it looked fairly clean but given it clean through with carb cleaner and a wipe out at reach what i could get to
Thread Tools
(T) Punto rough idel and some white smoke tinkerten Punto (Mk2/2b) 6 29-08-2012 13:54
(T) idel problem swan 76 Cinquecento / Seicento 1 03-01-2009 17:20
(G) fiat cinquecento sporting idel speed tairwin Cinquecento / Seicento 9 21-12-2007 08:53
(G) Erratic Idel problem Bennie Bravo / Brava 1 02-11-2007 09:56
(T) Accelerating on idel boeing1769 Bravo / Brava 2 09-06-2007 09:19
