Old 18-07-2019   #1
Noisy air con
I have a 68 94hp tipo lounge and the air con/climate control has become very noisy. It can be heard over the engine and goes off when switched off. Dealer has changed air con compressor but noise remains. Dealer now saying noise is normal on tipo. No problems on previous Fiats with climate control. Any ideas.....!!!!
Ian Stobbs is offline Reply With Quote Quote
Old 18-07-2019   #2
Re: Noisy air con
I have an old Grande Punto with automatic climate control, and that has always been noisy, so it doesn't worry me.
puntofan01 is offline Reply With Quote Quote
Old 18-07-2019   #3
Re: Noisy air con
I have a 120hp petrol 2019 lounge and my climate control isnít what Iíd call quiet but it is louder than my previous 500X .
twobigdogs is offline Reply With Quote Quote
Old 18-07-2019   #4
chris3234 has donated!
Re: Noisy air con
Is it a whiney type noise that.can be heard especially when the engine is decelerating?
If so mines like that
chris3234 is offline Reply With Quote Quote
Old 18-07-2019   #5
Re: Noisy air con
Changed the cabin filter? It’s amazing how much noise a blocked filter can cause.
Maker and voice behind the YouTube channel PuntoHowTo 10k subscribers canít be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is online now Reply With Quote Quote
Old 18-07-2019   #6
Re: Noisy air con
I had a 500x and air con was very quiet
It is a whining noise when decelerating
Where is the cabin filter and how can I change it?
Old 18-07-2019   #7
Re: Noisy air con
Quote Originally Posted by Ian Stobbs View Post
He tipo has the same basic under pinnings as a punto and as a Vauxhall corsa and Vauxhall Adam all of which use the same heater box, therefore this video covering the punto should be of some help.
Take out the filter, if itís less noisy then you know you need a new filter.
It will be fine to drive a few miles with the filter removed.
Thanks Ian Stobbs thanked for this post
Likes Ian Stobbs liked this post
Old 19-07-2019   #8
Thanks for video. Will change filter to see if it is the problem. The noise on climate control was not there when car was new but has increased iver time. It maybe filter is dirty so changing filter is required.
Old 21-09-2019   #9
Re: Noisy air con
How did you get on Ian. Was it the Tipo pollen filter and if so, where was it?
Dave Moore is offline Reply With Quote Quote
Old 21-09-2019   #10
Re: Noisy air con
Quote Originally Posted by Dave Moore View Post
It's behind the glovebox have to lower it down fully to see the plate that covers it
Open box pip out the black stopers on each side of the box then there a small peg the holds string to limit travel and slow opening it's on the right hand side of the box near the middle area hard to see
Then when it's open fulley down you should see the plate that covers it has two screws to hold it in place they are a huge pain to remove due to limited space
Old 23-09-2019   #11
Remould has donated!
Re: Noisy air con
Quote Originally Posted by chris3234 View Post
If you mean the two screws in the centre of the pollen filter cover,they don't need to be removed,they're for the fan housing,i thought the same !
Likes chris3234 liked this post
Remould is offline Reply With Quote Quote
Old 24-09-2019   #12
Re: Noisy air con
Checked pollen filter behind centre consol and it is still clean. Took car back to dealer and after a bit of a "stand off" they replaced the a/c compressor. It made no difference and deaker told me the noise was normal. After a few weeks the noise was gettig worse ( wasn't there when car was new) so went back to dealer, spoke to a different chap and he agreed there was a problem and suggested the compressor fitted was faulty and would replace it again. Will post results
Old 04-10-2019   #13
They got it replaced yet?
Old 04-10-2019   #14
Tipo booked on Monday. Not confident it will be fixed as they have had one try allready. Will post results when work completed
Old 10-10-2019   #15
Re: Noisy air con
Had my Tipo back to dealer to get another aircon compressor fitted. It is much quieter now and working ok.
(T) Something noisy... maybe air con compressor pulley bearings.... safc biker Bravo 4 27-11-2015 22:37
(T) Air Con Compressor Pulley Noisy zigleon Punto (Mk2/2b) 32 08-01-2015 19:17
(T) Air con noisy georgios1976 Grande Punto 6 20-04-2010 17:11
(T) Noisy Air-Conditioning (air con) Advice wanted caprimancars Punto (Mk2/2b) 1 29-06-2009 20:52
(G) Noisy Air-Con Greggers Stilo 22 14-06-2009 18:37
