FIAT Auto Specialist Team
Old 26-09-2018   #1
Headlight condensation
I've a 2017 Tipo, and now the cooler weather is approaching, I've noticed condensation on the inside of the o/s headlight cover (n/s is ok).
There's a scratch on the outside of the cover, but I'm pretty sure that it hasn't transgressed all the way through.
When I've experienced this problem on other (earlier) vehicles it's been straightforward to resolve by removing the headlight cover and then drying out the inside with a hairdryer. However I can't see an easy way of doing this on this model. Can anyone point me in the right direction, please?
tedglen is offline Reply With Quote Quote
Old 26-09-2018   #2
Trader Rating: 1
The Panda Nut has donated!
Re: Headlight condensation
Run with your lights on for half an hour. When you get home remove the bulb for an hour or two and replace it. This will dry the light unit out if its a dry day. If it returns you need a new headlight as the seal on the lens has probably failed. Make sure the rubber bulb cover is fitted correctly as this could also let in water.
The Panda Nut is offline Reply With Quote Quote
Old 26-09-2018   #3
JTD_Liam has donated!
My brand new 68 plate Tipo has a little misting around the edges of the headlight lenses a few times a week, particularly after driving in rain, but not exclusively. It's not enough to concern me, but if it gets worse as the weather gets cooler then I'll mention it when booking the first service.
If it gets dramatically worse & the unit begins to run with condensation I'll be asking for new headlight units/seals under warranty. I won't be fixing it myself having paid for a brand new car.
2003-2005 - 1996 Punto 75SX 5 Door -- 2004-2008 - 2000 Punto JTD HLX 5 Door -- 2008-2014 - 2004 Stilo JTD Dynamic 3 Door --
2014-2017 - 2013 Alfa MiTo -- 2017-2018 - 2016 Alfa Giulietta
Current - 2018 '68' Tipo T-JET S-Design - Street Grey
JTD_Liam is offline Reply With Quote Quote
Old 29-09-2018   #4
Quote Originally Posted by The Panda Nut View Post
Thanks,
Took two go's but worked a treat!
(G) headlight condensation pikey1965 Punto (Mk2/2b) 2 29-01-2010 00:31
(T) Headlight condensation BCD Panda 9 18-07-2008 22:55
condensation in my headlight tatlock Car Care 1 19-03-2008 16:20
(G) condensation in headlight fletcher11 Punto (Mk2/2b) 8 12-02-2008 17:37
Condensation in headlight - ok? John FIAT Boo Archives 2 25-12-2001 10:46
