Hi
Sei '98, decided to dump a quart of coolant out of header tank cap.
Refilled and blead, repeated, dump. Interestingly the heater and top rad hose were cool and not under pressure just before dump..only the little bleed hose to the header tanki was hot.
Replaced the thermostat, easiest to do but same synptoms so the water pump (10k miles from new) or both heat exchanger matrix or engine coolant passages blocked? The coolant did not look particularly mucky.
Probably the head gasket compromised, it is wet and windy so I'm going to have Sunday off...
Noel
Noel
