NetEnforcer
- Joined
- Mar 25, 2015
- Messages
- 4
- Points
- 2
Hey guys!
I've been desperately been trying to put my Bravo 1.4 12v working but no luck. Sometimes it seems like it's close, but no cigar :bang:
This is what happened:
After changing oil, filters & spark plugs, the car gained a new life, so i pushed a bit. After switching from 3rd to 4th gear (going a bit to the redline), it died on me. I pull over and the engine dies. I turn the key over and the engine turns but it just won't start.
What i have done since then:
- Fuel pump: checked if there was pressure, indeed it has.
- All relays and fuses: checked, all work. Replaced them for precaution, no luck
- Put fuel directly on the throttle body (not directly, on the bottom) and the car starts and revs, so sparks and everything else runs fine
- According to fiat ECUscan, all the sensors are ok and replying (temperature, rpm, etc) and the Fiat CODE gizmo gives it's "ok" for start, so immobilizer should be fine
- That "inertia" button on the bottom of the seat is working, as i tried both with and without the button, making a shunt.
- There's tension and current when you turn on the key
What comes next?
So i checked the injector, as this darn thing is SPI. The first surprise is that the injector that was on the car was the wrong one . It was for a Peugeot 106 1.0. Basically:
What was on the car: Bosch 0280150686 469CC/min@3bar 1.3ohms
What should be on the car: Bosch 0280150699 752cc/min@3bar 6.7ohms
The one that was on the car was ruined, it was short circuiting. So i got a new one, the correct one and it won't inject (tested the injector out of the car, it works and injects, but on the throttle body it won't budge).
So i thought "well, maybe it will work with a wrong one" so i got exactly the same one it was on the car and it's the same.
Fears
Something on the ECU fried? Although from ECUscan everything seems fine, maybe the driver from the ecu fried with the short circuit that occured with the old injector?
Any ideas? I've ran out lol
Sorry for the long post :devil:
What comes next?
Fears
