I’ve got similar issue with my 2.5d.
Fan runs when not used or started in days but now won’t switch off.
It’s the small fan, I tried to see if disconnection of the temp sensor on lower part of radiator would stop the fan.
It does not.
Does that likely point to one of 2 possibles,
1. Relay stuck on.
2. Wire connection break causing fan to run.
The second I’m guessing as a possibility.
First off , these relays are quite robust , but not infallible , so my first response would be , this is unlikely . The simple way to find out , is just swop them out . Both relays are identical .
Now with that said , let me give a brief run down of how this particular circuit works on the majority of vehicles ;
Power is taken from the battery . As it's fairly high power , it's run through something in the region of a 20-30 amp fuse on its way to the relay , usual pin 86 . The feed then reemerges at pin 87 and continues on its way to the actual fan motor/s .
Now let me explain , a relay is very basically a switch , not unlike any other switch you would use to say , turn the lights on . The difference is , it uses power , generally a low amperage current to turn circuits off and on . However , it does have a very important ability , it can safely switch very high amperage currents . It's because of this you will often find them on high powered circuits , such as the aforementioned lights , or to be more specific head lights . It's far easier , and safer to run low current wires around a vehicle than it is high . There are risks to running high amperage cables around , as these cables are often of a heavy cross section to handle both voltage drop , and the pressures of heat .
And anyway as most manual switches operate around the 5-10 amp range , there's not many that will handle 20 amps .
So now lets take a look at the control side of the relay . It takes it's power from fuse 1 , now this is a low amperage circuit protected by a 15 amp fuse , and directly feeds the relay so long as the ignition is turned on , via pin 30 . Notice this means the circuit is permanently powered up , but also notice this breaks with standard practice of placing the switch in the positive side to control the function . In the case of the fans , this is done by the earth . I've no idea the reason why this is the case , but it is common practice .
So on that note , the earth takes a different path , this is taken from the vehicle chassis , probably m47 under the battery , and feeds to the fan thermostat switch fitted in the lower nearside of the radiator . As is common with many older temperature sensors this is whats called a wax switch , as the wax melts this reveals a set contact to complete the circuit , and allow the current to continue on its path back to the relay at pin 85 . This earths the control circuit which in turn , turns the switch on , and so powers the fans up .
Now you say , the fan powers up , even when the vehicle is not in use , so this leaves us with an unusual situation . But not so unusual when you consider the system is permanently powered up . Personally despite finding this unlikely , it does sound like the switch is at fault , or should i say the relay !
As the relay control circuit is ignition controlled , a breakdown here is unlikely .
