NavNie
Hello everyone,
i am new here excuse my bad english, I use the help from a translation program.
A friend of mine has the following problem: he has a Ducato X250 2013, 150hp ECU Marelli 8F3, Motorhome with error
P0234 Overboost Pressure on rare occasions.
The MAP sensor and the vacuum valve have already been changed and work properly. During the analysis with AlfaObd the following status information:
Turbo valve condition with variable geometry: is not learned
Has anyone knowlegde about the AlfaObd function:
Turbo Actuator Pre-Align / Self Calibrate
If he starts the function, it will be rejected by the ECU with the message that the prerequisites are not met.
The following requirements have been prepared:
- Engine is idling
- Engine is at operating temperature
- Park brake applied
- No Gear
- No Breakpedal used
Hoping someone on the forum can help us.
Greetings Klaus
- Engine is idling
- No Gear
Greetings Klaus
