Hi, ive found a clutch on ebay, and it says it is to fit a 60bhp 1.2L 94-00, and as far as I am aware, the clutches for the 1.1 and 1.2 8v are the same, would i be right in thinking that?
It's safer to use EuroParts or Shop4Parts. When its open don't forget to make 100% sure the gearbox input shaft bearing is smooth. Also use a proper alignment tool.
ANY roughness or ANY slack you must change the bearings and seal or you will be doing it all in a few months when the clutch starts to slip with leaked oil.
Yes. But I'd use eurocarcare (Fluffy the Impaler) -- they've an eBay presence/shop as "It's Cento Time". Generally better quality and cheaper carriage.
