Sorry to butt in like this, but a mate of mine has an SPLX amp, been running it for about a year.
I will first admit that it is bugger-all use for running a speaker above sub range (eg: 6x9s), but It was fairly punchy for frequencies below 250Hz (Max Sub Frequencys).
As for overheathing, my mate ran his with the fins pointed down- the one position you are told not to as the heat produced rises and cooks the amp circuits!
. It was doing that for ages (at least 6 months) in use every day. Now its being used in another car, sat in the right position, working fine.
It did have some problems with shurting off when we were setting it up. I traced it to the fact that the input gain was set too high, or the speaker terminals were shorting out.
Look at your supply fuses, check all your connections aand set your gain and it should work fine.
Check this link for a good way to set up your gain
http://www.eatel.net/~amptech/elecdisc/gaincon2.htm
Be warned, its nice and complicated...
Arse
1993 Cinq SX, with the world's dodgiest fuel tank! Free fuel? Folllow Me!!
