MF2 doesn't get wired into ECU, its a stand alone injector driver unit.
It takes a feed from rev counter at back of instrument binacle, it also takes a +ve feed from ignition and a earthed behind instruments.
You then need the 2nd MAP sensor that has three wires that tell the MF2 when +ve boost is achieved, if the MF2 has been used before in this configuration then it will recognise this, if not there is a setting up process detailed in the manual which are available to buy on net somewhere, can't remember where as Alex22 found it when looking for a new loom for one.
The ECU can't see +ve boost, so you need some form of (BCD) Boost Cut Defender, (BDL if Van Aaken own) Boost de-limiter or any other name they make up for it, this wires into the feed to ECU from original MAP sensor.
