Spent a 3\4 hour this morning replacing the wiper drive arms, 2 new Wipex arms + those springy things on Ebay hope that is the last time I ever do them.
The reason for the clippy thing is both balls on shafts are worn\ rust pitts so a bit belt & bracers
Phoned Wipex 1500 BST on Monday bits delivered 1st post Tuesday Good service
Their service has been good when the other 2 we owned gave the same problemhave no connection other than satisfied customer.
The only thing with that job is to check wiper shafts for free play, all the ones I have done have been STIFF to say the least, it is an easy job to strip & clean them, watch for the little clip & there should be an O ring .
The sequence is clip out, washer, O ring, push out shaft there is another washer, cup seal, clean rust \ dirt off I try to fill housing with grease & re assemble as said about 3\4 to 1 hour with no rush
The motor assembly comes out with 3 x 6mm bolts after removing wiper arms & left hand plastic trim 5 self tappers (the one on the pillar different size head WHY
http://www.wipex.co.uk/
https://www.google.co.uk/search?q=w...ips+on+ebay&tbm=shop&spd=11046487656214279090
