Technical Wipers, again!
fido
Banffshire
Some of you may remember my posts about repairing the wiper linkage by fitting new balljoints. This is still working well but I have been having electrical problems with the wipers for some time. They only work when they feel like it. Often when you start up they don't work but come on after 5 miles or so. I think the problem is in the relay that controls the wipers, perhaps a dry joint on a pcb. The trouble is, I don't know which relay it is. I have a service manual on CD but so far have not found anything in there about relays. The owners handbook lists all the fuses but again does not mention the relays. Does anyone know which one it is?
Had same problem pulled back rubber where stalk goes into steering column sprayed contacts with wd 40 worked stalk up and down a few times mine now work perfectly
