ravingdave
- Joined
- May 6, 2008
- Messages
- 4
- Points
- 1
I've got a T reg Fiat Punto 60SX. Recently it seems to be losing water from the windscreen washer fluid, but only when the car is moving! Squirters back and front are working OK, with plenty of pressure.
Filled up the bottle to the top, and left it without moving for 2 days - no drop in water level.
Took the car out and drive locally for about 20 miles during the day (without using the washers). Get back and find approx 1 litre has been lost from the system.
Any ideas why this is happening, or where I should look?
The water bottle itslef appears to be embedded inside the wing, so I can't even see it, and the pipes also disappear into the wing, so I can't actually see where they connect. Can't see any obvious leaks from the pipes in the engine bay where they are visible, but highly puzzled why the water would disappear only when driving - if there were a leak I'd expect it to be dripping out all the time.
