You may not need spacers, as im currently running a set of vauxhall alloys, et 40, and the offset isnt right, so I get some rubbing, but only v.occasionally
Wobbly bolts can be bought from any motor factors, or maybe somewhere off the net
MODEL YEAR PCD OFFSET Bore
Astra/Kadet 84 to 98 4x100 35 to 45 56.6
So basically, as the auction says it came from a 1990 astra, the PCD will be 4x100 and the offset between 35 and 45. should fit fine, maybe need an 8mm spacer i think? or a 10mm.. depends what the offset of the alloy is.
The alloy has come this afternoon - i still havent found any spigot rings or wobbly bolts. They seem to only sell them in full sets! but i only need wobbly bolts and spigot rings for 1 alloy!!
IF ANYBODY HAS 3 WOBBLY BOLTS FOR SALE - or SPIGOT RINGS - Could you let me know Thanks!
If he already has a set of these on his car, and its going to be a spare, then surely he doesn't need anything.. Just use whats already on one of the other wheels when you need to replace.
Yes but i have curbed the back left alloy quite bad and the alloy i brought is in immaculate condition! So i just want to change it as soon as possible! hopefully at the weekend! So thats y i want the wobbly bolts and spigot rings!
