What is the make/model and how many pipes go to it? Could be a combi.
CH usually has a flcik switch somewhere around the house nearby plug sockets if this is off then you'll get nothing.
http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=A431905&ts=73276&id=32153#
Liam
i took the boiler apart once when i was left alone and had no heating. Then I realised the 'heating' button was in the off position
You enter the room to find 3 war bikes.
[Go forwards] [leave]
You see a Power Generator.
[Investigate] [Go Back]
The power generator is broken
[Fix] [Go Back]
FIX: You do not have the tools and now you have 3 minutes to escape before the generator explodes.
Pressure looks a bit high.
If the boiler hasn't been running then it should be at about 1 Bar.
generally the installer will set the guide needle to the recommended level. in my case it is 1.5 bar, so i guess it depends on the application. so i would have thought the pressure was at the correct level.
plus most boilers will not top up their own water pressure... it has to be done manually with an external valve going to the boiler.
Unfortunately, it looks like you need a heating engineer. Your folks may have an insurance policy that could cover this, so have a word with them if poss.
If you lived closer I could look at it my self.
If you've got hot water its not the boiler, the 3 way valve is usually near the tank. When you turn the heating on you should see a plastic arm move on it.
Yes these things do stick and a tap with a hammer usually does the trick, But...
He said the low pressure light is on..
Hot water could be from Immersion heaters?
