Technical Why is my sei cutting power
Wellingborough
2002 'sX'
Basically i changed my clutch and gearbox and since everytime the ecu cuts power when i wheelspin ( and today it even did it when i pushed into a corner and the inside wheel span)
The Injector Light illuminates but the car resumes normally once traction is resumed
Thanks Andrew
wheel spin shouldnt affect anything.
check your earths! sounds like its a loose earth, specially if your box been out, check the earth on your passanger wing.
all im sayin is i dont know waht can cause this, but im telling you there isnt a sensor or ecu or anything in your car that will read wheel spin so thats not the cause lol.
check the earth on the coilpacks aswell,
on the back of the coil pack :). i had a problem that was spluttering in corners and it was this earth.
other than that im unsure, does definatly sound like something is earthing out or touching and shouldnt.
